跳转到主内容
加入维修社区 - 创建账户
Samsung Galaxy Tab 12.2(2014 年发布)的维修信息。型号:SM-T900、SM-T905。
replaced battery in Samsung Galaxy tab sm-T900 now screen doesn't work
Hi my Samsung Galaxy pro tab sm-T900 wasnt charging but the screen worked. We put in a new battery and charging port and with new charger. When we turned in on you could hear sounds coming from if just no display on a black screen. Any ideas how to fix it? I also was hoping to find a schematic of the inside to identify the video/monitor connections to check and make sure they are connected. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
@gretal few things that may have happened. Something did not get connected, something came loose or something got broken ;-). Anyhow You will have to disassemble it once more. Check all the connections, remove the cables from the connectors and make sure that there are no bend or broken pins specifically on the LCD cable.
Download the second picture and use your graphics program to view it. It’ll be to small to see it in the viewer on here
这个答案有帮助吗?
得分 1
1条评论:
where i can download it the schematic
完成的
添加一条评论
添加你的答案
Greta Lovejoy 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 18
总计 493
