跳转到主内容
The Powerbook 5300 is a 10.4 inch Apple laptop running on Macintosh System 7. It was the first to use the Power PC architecture.
1 个问题 查看全部
Repairing power connection , intrenal
When power cord is connected,no power ,green light does not go on.
Is there an easy fix to this or must I re solder ,on interior of book.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
已选择的解决方案
IIRC that model had known problems with the battery and the power connector. Check the cord with a multimeter to be sure its providing voltage to the computer. If it is you will need to check out and quite likely need to repair or replace the power connector. I am including a link to the guide that comes closest to assisting you with disassembly. Good luck.
Apple Powerbook 5300 Hard Drive Replacement
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Douglas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 784
