Power but no heat - thermal fuse seems to be ok
Our toaster oven turns on and lights up but does not get hot. After some research I thought it might be the thermal fuse but after taking the dang thing apart the fuse seems to be fine when tested with a multi meter. So maybe it’s the heating elements but those are expensive and tough to get to. Before investing time and money anybody have any ideas about how to test if it is the heating elements? I mean, would they all go out at the same time? Other thoughts about problem.
1条评论
Raphael Gutierrez verify your toasters make and model. Since you checked everything else already you could always check the heating elements.....
由 oldturkey03 完成的
