跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 个问题 查看全部
The temp display has changed significantly
@ladytech I have the same issue. I have noticed that after unplugging and plugging back in, the temp display has changed significantly. Like before unplugging it says -5 freezer 55 fridge and then after unplug/replug it will say -1 freezer 59 fridge. Too short a time for temp to change that much.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
@joshbrasel I have the exact same problem. Did you ever resolve the issue?
完成的
@joshbrasel Dang. I have already replaced the fan but that didn't do the trick.
完成的
@ssluter do you notice any frost forming anywhere in the freezer or fresh food section?
完成的
@ladytech No. See photos from the last time it happened: https://imgur.com/a/inXCYN5
The first time it happened, the top of the evaporator had frost. Now every time we notice the temp going up, we pull the plug for a minute then plug back in. Seems to fix it every time.
完成的
@ladytech One more clue - the fridge is fine unless we turn on the icemaker. Not a coincidence, every single time we turn on the icemaker the fridge temp goes up. I haven't tried to turn it on in over a week, and we haven't had any issues.
完成的
显示更多的1条评论
添加一条评论
1个答案
已选择的解决方案
@ssluter if the sensor located on the evaporator coil was incased in ice, it should be replace. It could give a false temp reading to the board. Unplugging will reset the board.
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
ssluter 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 28
