The temp display has changed significantly
@ladytech I have the same issue. I have noticed that after unplugging and plugging back in, the temp display has changed significantly. Like before unplugging it says -5 freezer 55 fridge and then after unplug/replug it will say -1 freezer 59 fridge. Too short a time for temp to change that much.
6条评论
@joshbrasel I have the exact same problem. Did you ever resolve the issue?
由 ssluter 完成的
@joshbrasel Dang. I have already replaced the fan but that didn't do the trick.
由 ssluter 完成的
@ssluter do you notice any frost forming anywhere in the freezer or fresh food section?
由 LadyTech 完成的
@ladytech No. See photos from the last time it happened: https://imgur.com/a/inXCYN5
The first time it happened, the top of the evaporator had frost. Now every time we notice the temp going up, we pull the plug for a minute then plug back in. Seems to fix it every time.
由 ssluter 完成的
@ladytech One more clue - the fridge is fine unless we turn on the icemaker. Not a coincidence, every single time we turn on the icemaker the fridge temp goes up. I haven't tried to turn it on in over a week, and we haven't had any issues.
由 ssluter 完成的
显示更多的1条评论
