跳转到主内容
加入维修社区 - 创建账户
Repair guides for the Samsung Galaxy Tab A series of tablets. Released in 2015.
Why won't my tablet recognize my pin?
I made my pin really simple (2905) but it wouldn't recognize it. I used “Find My Mobile Samsung” to unlock it, and now I would like to change my pin. The thing is, it needs me to enter the pin to be able to change it. I tried, it won’t recognize it. What can I do? It would suck if I had to use Find My Mobile to unlock my tablet every time.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
6条评论
Also, its a Galaxy Tab A 2019
完成的
My Samsung won't let me use my pin code.ever time i put in my code it says wait 30 seconds so i do same thing wait 30 sec iam stressed.
完成的
I have exactly the same problem right now
完成的
@feralfaerie What did you do to go back in your tablet? Because I'm having that problem right now
完成的
I need a phone that was connected to my tablet,iv tried factory reset
完成的
显示更多的1条评论
添加一条评论
3个答案
最有帮助的答案
Hi,
Haven’t had to try it yet but according to this (scroll down to Unlock):
“If you've forgotten your pin, pattern or password and are  unable to access your device  the unlock function will remove all screen lock types (including any biometric info). You'll need to enter your Samsung Account password one more time to send this function to your device”.
Are you doing the same as the procedure outlined in the link?
这个答案有帮助吗?
得分 2
添加一条评论
I just had this issue, saw on the lock screen that the find my mobile app was updated, then it wouldn’t recognise my PIN, stressing for sure, so I did a bit of digging… First of all find out which model you have and find out how to restart your tablet by holding certain buttons, I have a SM-T510, my restart was holding the power and volume down buttons until the screen went black, logo appeared. Tablet restarted and my PIN worked again!
这个答案有帮助吗?
得分 2
1条评论:
Tried that. Didn't work
完成的
添加一条评论
To force a restart hold down the power button on the side of tablet and at the same time hold down the volume up for 45 seconds and it should restart. Its worked for me. I've had to do this twice since I bought it in September.
这个答案有帮助吗?
得分 2
3条评论:
Thanks. This worked for me.
完成的
None of that worked for me, so !#^&@@.
完成的
I just bought a new Android tablet and it is asking for the pin number, how would I know that if I just bought it from Walmart
完成的
添加一条评论
添加你的答案
haw yee sister 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 38
总计 9,777
