跳转到主内容
发布于 2012 年 6 月, 型号 A1278. Intel 处理器,支持 Turbo Boost, 最多 512 MB DDR5 显存
1624 个问题 查看全部
Installed Catalina on a MacBook Pro 13.3" - Mid 2012
So i know that this Macbook does not support Catalina but I went ahead and install it. The installation had several glitches with the circle and cross but it did made it to the desktop. Got online without any issues.
I did not used the computer all weekend but when i turned on the computer, it did turned on but it stop charging then it completely shuts off then i will not turn back on nor charge at all. Can this be related to Catalina, what could have happened? Is there a way to turn back on and install back High Sierra? Please assist, thanks!
Model #:A1278
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论:
Let’s get a better view of things, install this gem of an app! CoconutBattery take a snapshot of the apps main window and post it here for us to see 在已经存在的问题里加入图片
完成的
Thanks for responding, like i mentioned, my mac book won’t turn on nor it will charge so i cannot install coconut battery.
完成的
@uitadmin - I thought you had it working, if the system is not responding at all then that is more likely a hardware issue.
What is the color of the MagSafe chargers LED Green or Amber?
完成的
Neither green nor amber are showing up. I've tested with different chargers.
完成的
添加一条评论
1个答案
Lets check and clean the MagSage connections. Follow this Apple T/N Apple Portables: Troubleshooting MagSafe adapters
Are yours clean? Here’s an example of a failed connector
If you looks damaged or can’t get it clean you’ll need a new MacBook Pro Unibody 13" and 15" MagSafe DC-In Board and here’s the guide to put it in MacBook Pro 13" Unibody Mid 2012 MagSafe DC-In Board Replacement
MacBook Pro Unibody 13" and 15" MagSafe DC-In Board图片
产品
$9.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gabriel Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 132
