跳转到主内容
No WiFi or Bluetooth after replacing battery and speakers
I’m not sure where to begin looking for the problem. Can someone point me in the right direction? I have no Wi-Fi or Bluetooth after replacing the battery and speakers on my MacBook Pro 13 inch retina late 2012 laptop. I followed the tutorial exactly and did not seem to have any problems during the repair.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Either the I/O board cable or the I/O board its self has an issue
MacBook Pro 13" Retina (Late 2012-Early 2013) I/O Board Data Cable
MacBook Pro 13" Retina (Late 2012-Early 2013) Right I/O Board
Here’s the guide MacBook Pro 13" Retina Display Late 2012 I/O Board Replacement
Replace an I/O board compatible with the Late 2012 or Early 2013 MacBook Pro 13" Retina laptop. Fix problems with display, and data connections. Includes the USB, HDMI, and SDXC ports.图片
产品
$49.99
Replace an I/O Board Cable compatible with the Late 2012 to Early 2013 MacBook Pro 13" Retina laptop. Fix the connection between the I/O Board and the Logic Board.图片
产品
这个答案有帮助吗?
得分 1
3条评论:
I’m an amateur here so I really appreciate your time. I made sure all cables were reconnected properly. In your opinion should I proceed with replacement of the recommended items? I was extremely careful when I replaced the battery so I don’t think I damaged anything. Are there any other things I should check first? The only other ‘symptom’ before I replaced the battery was occasional difficulty getting the laptop to connect to a Bluetooth speaker. It would sometimes take multiple attempts to connect with no apparent cause. Thanks again.
完成的
Try reseating the I/O cable, if that fails replace it and test again.
完成的
Will do thanks!
完成的
添加一条评论
I’m having this same issue. Did you solve it in the end?
这个答案有帮助吗?
得分 0
1条评论:
@henrychugh26 - Did you try resetting the cable and if that didn’t help replace the cable. 40% of the time reseating fixes it and the other 40% replacing is needed. And lastly 20% the board is corroded up.
完成的
添加一条评论
添加你的答案
Angela Desjardins 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 10
总计 595
