跳转到主内容
The original Xbox is Microsoft's first widely popular video gaming system. It has an easily identifiable black case with 'XBOX' emblazoned on the top and front. Repair is easy with common tools.
170 个问题 查看全部
Accidentally shorted power supply, wont power on
i finished modding my xbox and in the rush of excitement dropped my ssd onto the power board, the metal plate with holes in it, it gave me a small shock and welded the ssd to the top of it before the safety switch went off, im assuming since removing the ssd that the metal plate will be fine and ive just blown the fuse near the connector, is there any advise or suggestions to help with replacing the fuse or other things i should look at? its a 1.6 with a delta 1 row psu
the ssd is alive and just seems to have been external damage which gives me hope for the rest
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
After you shorted the PSU, the fuse probably popped. Try locating the fuse and replacing it with a new fuse. If that doesn't work, then the other part of the PSU is fried and you have to replace the PSU. Hope this helps.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
matthewyeardley 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 209
