跳转到主内容
Model A1225 / Early 2009 / 2.66, 2.93, or 3.06 GHz Core 2 Duo processor
iMac does not recognize WD Blue SSD
I have replaced the HDD of my iMac by a 1T WD Blue SSD, but the computer is not recognizing the SSD. I booted from a live linux CD and the drive is not showing up on for instance lsblk. Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
I would suggest to check the connection. And / or test the drive in another computer/external case.
完成的
添加一条评论
1个答案
This is the problem with the Fixed III SSDs in SATA II Macs like this - they do not work! You need a drive with a SATA II mode, or a Fixed II SSD.
As to what drives I’d recommend there are two:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Tsog Gantumur 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 9
总计 270
