跳转到主内容
加入维修社区 - 创建账户
本页面将为你提供 Dell Precision M6700 的维修帮助。我们提供了包括指南和手册在内的资源,以辅助你尝试维修 Dell Precision M6700。
2nd samsung ssd not going in to the computer all the way
I am trying to install a 2nd hard drive in my m6700 when i try to slide it in, it is not going in all the way so i can screw it down? its a ssd samsung 860 drive looks the same on the end as a reg drive I have it the right way in the caddy it just is not going in? What am I missing
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Size may be your problem.
Is the drive HDD (mechanical) or SSD ?
If HDD then:
2.5" hard drives normally come in one of three thicknesses:
  • 12.5 mm - these are the Super-Phat drives that probably only larger laptops (DTRs and workstations) can fit. They usually have three platters instead of two, enabling higher capacity.
  • 9.5 mm - this is the most common size and should fit most laptops without problems.
  • 7 mm - these slim drives are used in thinner laptops (like ultraportables). Most SSDs are also in this size, and usually include a plastic bumper to increase the thickness to 9.5 mm in case the HDD mounting system requires it.
这个答案有帮助吗?
得分 2
5条评论:
I have a ssd thin and a reg mech hard drive neither would lock in. I don't know what I'm doing wrong I see inside where they lock in. I have them in the right direction. They just won't lock on so I can screw it down?
Bob
由完成的
@Bob Cgar TV
Here's the owner manual.
Go to p.17 and check if that helps you any.
由完成的
@Bob Cgar TV
Did you use the rubber filler/ plastic bumper to increase the thickness to 9.5 mm ?
由完成的
I think maybe the cage is not right I ordered a new one I tryed with 9.5 and &mm ssd neither will slide in
由完成的
@Bob Cgar TV
Hi Bob,
Did you get it sorted out?
由完成的
添加一条评论
添加你的答案
Bob Cgar TV 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 9
总计 384
