跳转到主内容
加入维修社区 - 创建账户
Acer Aspire One D270 是一款配备 10.1 英寸显示屏的上网本。
Netbook won't POST after disassembly
The hinges on my laptop broke and the power switch kind of blocked when the lid was in a certain angle and also just moving the lid sometimes activated the power switch so I decided to disassemble the device, clean out the broken pieces of plastic, glue the hinges onto the lower part of the shell (could not screw them back in place, too much plastic was broken) and put it back together. Everything seemed to work out fine but now it does not boot any more: no screen light, no fans, no beeps, nothing.
I disassembled it again and removed some cables (screen, antenna, speaker, drive) but to no avail. I’m pretty hopeless at this point. But what did I do wrong? Could I have scratched to board that hard? Did I create a short circuit somehow? Can my greasy fingers ruin something? I was SO close to fixing this thing…
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Well no screen suggests a power problem. Check the connection from battery to charger to motherboard? I guess something could actually be broken, but more likely just got shifted or disconnected during your activities.
这个答案有帮助吗?
得分 0
2条评论:
Do you mean checking with a multimeter? I don't have such thing and I don't know how to do that. Maybe I should get some tools and education. Might be worth it.
由完成的
@mender Try to disassemble your laptop again just to make sure everything is seated properly specially the ribbon cables that connect the LCD into the motherboard and do also check all other ribbon cable that is located inside your laptop. If all these will not work do also try to reseat the RAM, remove them all for couple of seconds then put them back in making sure that everything is seated properly into each slot.
由完成的
添加一条评论
添加你的答案
Salvador Dali 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 30
总计 524
