跳转到主内容
The larger of Apple's MacBook Air laptops featuring dual microphones and 802.11ac Wi-Fi connectivity.
465 个问题 查看全部
Lines appear on screen while hinge is opened
I have a MacBook Air that shows distorted vertical lines and blocks on the screen when the hinge is opened and closed. I suspect that the screen cable may be bad since it only happens when opening the lid, and not when pressing around the LCD. Can anybody else give me some knowledge on this? Thanks in advance.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Your display is damaged not the cable!
What is happening is the tension you are applying to the lid when you open it or close it causes the fine metal oxide deposits which are the wires that make your LCD work on the glass to break apart and then re-connect.
Similar to how a piece if torn paper which have a bunch of lines drawn across can be joined together so they appear as they once were before the page was ripped.
What likely happened is something heavy pressed on the lid or you gave the system a good bang.
Here’s the needed guide MacBook Air 13" Mid 2013 Display Assembly Replacement and here’s the needed part MacBook Air 13" (Mid 2013-2017) Display Assembly
MacBook Air 13" (Mid 2013-2017) Display Assembly图片
产品
$314.99
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dylan Mclaughlin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 203
