跳转到主内容
The Dyson V6 Absolute is a cordless, bagless cleaner released in September 2014, with HEPA filtration that captures allergens. Used for all floor types and weighs 5 pounds. Identified by model number SV09.
19 个问题 查看全部
vacuum cleaner works on-off
Situation: 2 years old V6; canister is empty and clean ; the motor filter is clean. the MAX button is OFF. All is OK with the cleaner. BUT:
After a full charge, motor kicks out after 2 minutes of operation- put on charge again for one minute- motor starts again for an other minute- put on charge few more minutes- vacuum cleaner OK for ONE minute; and so forth. Could the life of battery has ended?
Note: on the body, the light is solid blue when in operation and flashing every time the cleaner stops.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
If your Dyson v6 Absolute vacuum cleaner unexpectedly turns off during use, see the Dyson v6 Absolute Shuts Off While In Use problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
The absolute shut off problem pages doesn't address this problem. All the fixes have been gone through and it still shuts off all the time.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Jean Claude Bourcier 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 35
总计 1,168
