跳转到主内容
Model A1419 / Late 2013 / 3.2 & 3.4 GHz Core i5 or 3.5 GHz Core i7 Processor, ID iMac14,2
340 个问题 查看全部
Why does the monitor no longer stay in place...it just flops forward
Display does not stay at the adjusted angle, as if fasteners have come loose. Always returns to a facing down position.
Is this something I could fix at home or would I need to take it to a repair person. Are there specialized tools available on iFixit for this repair?
Thank you!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
3条评论
Which model do you have?
Plug in your systems S/N here EveryMac - Lookup Let us know what you find.
完成的
model identifier: iMac 14, 2
late 2013
iMac 27 inch
thank you for responding!
完成的
dan, thank you for taking the time to help me with the monitor issue.
完成的
添加一条评论
1个答案
已选择的解决方案
You have a very limited window of time here to get this fixed for free!
Apple had a defect in the stand hinge as the counter spring would become loose. It’s a big job as the logic board will need to be removed to gain access to the hinge part that needs to be replaced.
Apple Offering Refunds to Customers Who Paid for iMac Hinge Repairs
Contact Apple support to arrange a repair. If you missed the window I would just use a wedge between the case and the stand.
If you really want to fix this on your own it will require removing the display and the logic board: iMac Intel 27" EMC 2639 Logic Board Replacement Make sure you follow the guide to the letter! As you can damage the display if you don’t. You’ll need this kit to get the needed tool [关联产品丢失或禁用: IF174-005]
With the logic board out you can now get to the hinge to repair it.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
ellen dimsdale 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 121
