iMac only white screen with chime
This iMac 17” 2006 when powered on has chime but only white screen, any solutions?
Generally a white screen issue is related to a failed hard drive.
Insert your original system installation DVD and boot holding down the “C” key. If you do not have that disk you need to have a system compatible external USB source to boot from. Another alternative is using another comparable MAC in Target Mode.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 6
总计 73
1条评论
Could you try the suggestions from this: https://blog.macsales.com/40844-how-to-r...?
由 Jonas A. 完成的
