跳转到主内容
加入维修社区 - 创建账户
1.8GHz dual-core Intel Core i5 or dual-core 2.0GHz i7. (Turbo Boost up to 2.8GHz) with 3MB shared L3 cache
MacBook won't connect to hard drive due to maxed out memory. Options?
A day after I installed a new program for work, my laptop froze and shut itself off. When I tried to turn it back on, it showed the flashing question mark folder. I spoke with Apple support and tried holding ⌘+R, option+⌘+R, and shift+option+⌘+R on different occasions. I was able to reach disk utility but my internal drive would not show up. After more restarts, eventually it only showed an error code starting with “-6xxx”. The representative told me I would need to bring it in to be serviced because the hard drive could not be detected. I took my laptop to get diagnosed in person by a third party and was told that it was overcapacity and that the only option was to replace the hard drive.
I have files that I would like to save from this laptop but mainly I just need it to work again. What are my options here? Will everything be fixed if I can just replace the hard drive myself? Will this restore my files as well or will they be lost?
I have two external hard drives that might be useful. One is empty (but formatted) and one has a backup from a few months ago and other files on a separate partition.
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
The SSD stick can be easily upgraded:
[关联产品丢失或禁用: IF188-104-3]
From OWC: OWC Aura Pro 6G SSD for MacBook Air 11" and 13" (Mid 2012)
OWC makes an external enclosure for the sticks called the Envoy.
https://eshop.macsales.com/upgrades/macb...
MacBook Air 13" Mid 2012 Solid-State Drive Replacement
Replace or upgrade the SSD in your laptop. This SSD is compatible with a Mid 2012 MacBook Air 11" or 13" laptop.图片
产品
$67.99
这个答案有帮助吗?
得分 3
5条评论:
Thanks for your response. I have very limited knowledge about computer hardware. What I do know is only as a result of having some problem and attempting to troubleshoot it myself. Will upgrading the SSD allow me to start up my laptop again like normal? Why would the external enclosure be necessary?
完成的
If you Mac will not see your drive internally, your only real option is to put it in an external enclosure. You can install an new SSD stick and use internet Recovery to format it and install the original system.
Can you currently boot from one of your external USB drives?
完成的
I installed Catalina onto my external SSD and was able to boot from it. I am currently responding from my laptop. After logging in, I was prompted to enter the password for my old MacBook account (on the internal SSD). A few minutes later, an alert saying "The disk you inserted was not readable by this computer." with options to "Initialize..." "Ignore," or "Eject." No matter which option I choose my laptop keeps restarting itself. When turning back on, I get a screen that says "Your computer was restarted because of a problem. Press a key or wait a few seconds to continue starting up." I get about 10 minutes of use before it happens each time.
EDIT: This time I have chosen not to pick any of the options when I get the "disk not readable" alert and nothing has happened yet!
In disk utility, the only internal drive is called "SandForce{200026BB} Media". It shows that it is uninitialized and has a capacity of 33 KB. First Aid takes one second and says "Operation successful" but doesn't seem to have done anything useful.
Honestly, at this point I just want my laptop to be usable until I am able to get a new one once the new year rolls around.
完成的
I don't remember how I got to this before the last restart, but it might be useful to you:
panic(cpu 2 caller 0xffffff800a414e67): "AppleAHCIDiskQueueManager::setPowerState(0xffffff80162e3900 : 0xffffff7f8c8f55d2, 3 -> 2) timed out after 100369 ms"@/AppleInternal/BuildRoot/Library/Caches/com.apple.xbs/Sources/xnu/xnu-6153.141.1/iokit/Kernel/IOServicePM.cpp:5296
Backtrace (CPU 2), Frame : Return Address
0xffffff809dd03b40 : 0xffffff8009d1a65d
0xffffff809dd03b90 : 0xffffff8009e54a75
0xffffff809dd03bd0 : 0xffffff8009e465fe
0xffffff809dd03c20 : 0xffffff8009cc0a40
0xffffff809dd03c40 : 0xffffff8009d19d27
0xffffff809dd03d40 : 0xffffff8009d1a117
0xffffff809dd03d90 : 0xffffff800a4c1abc
0xffffff809dd03e00 : 0xffffff800a414e67
0xffffff809dd03e50 : 0xffffff800a414749
0xffffff809dd03e60 : 0xffffff800a42bcde
0xffffff809dd03ea0 : 0xffffff800a4134f8
0xffffff809dd03ec0 : 0xffffff8009d5c605
0xffffff809dd03f40 : 0xffffff8009d5c131
0xffffff809dd03fa0 : 0xffffff8009cc013e
continued...
完成的
Looks like the error is getting caught in the spam filter. I have pasted it into this google doc instead: https://docs.google.com/document/d/1hiFZ...
I have also included a screenshot of my internal drive as it shows in disk utility
完成的
添加一条评论
Hi Nicole, I am having the same issue with my 2015 MacBook. I’ll let you know if I find the solution but you in the meantime can use your free external drive as your hard drive. My advice first of all is to repost your original question but give details on every little piece of info because an expert will need it to diagnose and give a solution. what year make model is there yes but, what os? when did you get it? Do you know which File system was used HFS or APFS or? every little piece of info you have— be redundant . You should note any hardware you can .. some of those older books have very specific probs like the hd cable will go bad in certain models and so on
But ok to just use your computer you need to boot into recovery mode: opt+cmd+r and you need internet. once there you should download OS (i forget the exact option but you are re downloading the mac OS) make sure your external drive is plugged in and download the new OS to there. If the new external drive is greyed out then you must change the file system in disk util. At least this way you can use the computer till you fix the problem.
One thing to note: my mac will load way way easier if I remove the [SSD that won’t show up]
once you get ur MacBook going use a small thumb drive and create a bootable installer (easy) Apple provides instructions… use “sierra” OS for this bootable drive unless you know everything you have is in APFS apples new filing system…
Hope this helps!
这个答案有帮助吗?
得分 1
2条评论:
You have a back-up. You should use recovery to set up the external drive then restore from backup when you are prompted. then work on getting your data...
完成的
Hi Mikhail, thanks for the response! I was able to boot from my external SSD but am still experiencing problems from the internal drive. I'm honestly not sure of any of the other details but I will try to get some more information and include it in a future post if I can't figure out a way to stop my computer from restarting on its own.
完成的
添加一条评论
添加你的答案
Nicole 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 23
总计 331
