跳转到主内容
Repair guides and support for the fourth generation of Ford Mustang, including the Mustang GT and Mustang Cobra.
58 个问题 查看全部
has a dead miss to it and blinkers wont work
I habe a 2004 ford mustang base body 3.8 v6 car run and everything just has a dead miss to it and blinkers wont work i replaced the coil pack what would i do next and i replaces blinker flasher fuses and the relay but blinkers come on but wont flash can some one help please
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
First do a compression test. If the compression is good pull the codes and find the cylinder that is missing and switch plugs and erase the code and see if the mis changed cylinders then if that doesn't work try switching the coil and erase the code if that doesn't fix it then it needs a injector.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
amerrell66 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 41
