跳转到主内容
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
2376 个问题 查看全部
Battery Connector Broke off?
I pulled the battery off wrong and pulled the connector off the board. I soldered it back on and its working now because when i hook a battery up it will turn on without being plugged in. Im just wondering about the connections on the connector i was able to solder the four contact points in the rear but the two on the front that are underneath i dont know how to get at to solder them but do they matter as long as the four in the back are soldered?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
3条评论
does anyone know
完成的
come on someone help me out
完成的
jared, have you checked on your PCB to see where the two other points connect? Any traces coming of them? If your battery works, charges etc, it is possible that those two are to hold the connector onto the board.
完成的
添加一条评论
2个答案
已选择的解决方案
I guess im better than you at this stuff then because i replaced mine and now its working 100% again :)
这个答案有帮助吗?
得分 0
1条评论:
+ excellent job and congratulations on getting it accomplished.
完成的
添加一条评论
There's no way to get it fixed bud, you'll have to get a new one to replace it right away.. Wish you luck
这个答案有帮助吗?
得分 0
3条评论:
as you can see, there is always a way. Have some faith....;-)
完成的
Quoting "Replace it right away" If you didnt get it, means replace the batery, i guess its what you did.
完成的
actually no i replaced the battery connector on the board not the battery what i did actually requires skill
完成的
添加一条评论
添加你的答案
Jared 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 831
