跳转到主内容
Does not go to sleep when lid is closed
Hello,
After replacing the battery on this computer, the computer does not go to sleep when the lid is closed. Everything else works fine. Maybe it is a damaged hall effect sensor?. What would most likely have been damaged in the process of replacing the battery that would have caused this? How would I go about fixing it?
Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Hi there,
Is the display setting set to always on?
这个答案有帮助吗?
得分 0
1条评论:
No. No software settings were changed after the battery was changed, including the display settings. It used to go to sleep before.
完成的
添加一条评论
添加你的答案
Albert Einstein 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 50
