跳转到主内容
What is the recommended solution for pixelation on the screen?
Right where the URL bar is when I'm using chrome or any other browser towards the far right there is a spot that looks like it's pixelated - a very small line that is at a 45 degree angle from the x axis and about a quarter of an inch thick. What parts should I buy to fix it and which tools will I need?n
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
Can I get a picture please
完成的
添加一条评论
1个答案
It looks like the screen is damaged and will need to be replaced or you can live with it.
这个答案有帮助吗?
得分 0
1条评论:
How much would it cost to replace the screen ? Because I'm trying to sell it and it is perfect minus the small pixelation. Also I imagine I would need some special tools to accomplish the job, I'm am engineer but I work mostly in design but it seems like it would be straight forward (if time consuming) with the proper equipment. Suggestions? Also it should be mentioned that the area of the screen identified is the only problem area and often it will disappear and work fine. It never exacerbates the display issue and is confined to the small space identified.
完成的
添加一条评论
添加你的答案
Def Jaring 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 124
