跳转到主内容
发布于2018年9月21日,型号為 A1920、A2097、A2098、A2099、A2100。相容的行動網路為2G、3G、3G+、4G(LTE)、4G+(LTE Advanced)。A2100僅有nano-SIM,其餘版本為nano-SIM與eSIM。儲存容量有64 GB/25B GB/512GB三種。顏色有銀色/太空灰(深空灰)/金色三種。(機器讀作iPhone 10s)
398 个问题 查看全部
Changed Calls Speaker. FACE ID Not working anymore
Hello, i recently changed the front speaker of an iPhone XS Max (the one you use on calls near your ear) and Face ID stopped working, i checked multiple times all the sensors that comes with the speaker, restarted the phone and nothing. I didnt touched the screen because it was working flawlessly. My only assumption is that the part has a failure? Probably with another speaker it will work?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Did you replace the whole assembly or solder on a new speaker. The proximity and flood sensor are paired to the phone and if you change that assembly face Id will not work. Also if you change the original from camera face Id will not work.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Demetrio 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 36
