跳转到主内容
Removing the lower case of an early 2015 MacBook Air
I need to repair what I’ve identified as an early 2015 MacBook Air (Model A1466, EMC2925). Every guide lists 10 screws to remove. However, I can only see 6: 4 on the leading edge of the front of the computer, and 2 on either corner of the hinge side.
I used a plastic wedge to pop two plastic snaps on the sides, but the hinge side won’t come apart without using a lot of force, and it seems as if I’m bending the case.
Is there something I’m missing?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
I think you mis identified your system!
I’m suspecting you have in fact a 2016/17 13” MacBook Pro Function Key model which uses USB-C connections for the charger. It has 6 screws unlike the older 2015 13” MacBook Air or Pro systems.
Here’s a comparison of the bottom cover & the guides for each:
这个答案有帮助吗?
得分 1
4条评论:
Thanks, I figured I must have.
I use everymac.com to identify systems, and normally they’re spot on. However, all that came up when I entered the information - including the serial number - was a MacBook Air.
Any thoughts on a better way of identifying the model of the computer if it won’t turn on?
完成的
I would focus in on the ports How many and if you can identify the type of ports.
So in your case if I'm correct you should have two USB-C ports (Thunderbolt 3). If your system has more or different what are they?
If you have two USB-C ports then you either have a 2016 or 2017 model. At this point its just minor differences the diagnostics are the same.
完成的
To figure out what's wrong can you tell us a bit more. Are you using the original charger the system came with as well as the cable. Do you get any response on the display? I find I need a USB-C power meter to figure out if the system is getting power and what the system is taking in.
完成的
Well Dan, you're going to find this humorous. The computer I need to work on is indeed an early 2015 MacBook Air; however, I'm at my friend's home, and their family has a 2017 MBP that has the exact same exterior shell casing design! I grabbed the MBP pro thinking it was the Air. I didn't even check the Model and EMC number. That's taught me a lesson...
完成的
添加一条评论
Well, I just figured it out. After removing the 6 screw, the case is actually removed by sliding the bottom away from the hinge side.
这个答案有帮助吗?
得分 0
1条评论:
@czjohn - check my answer as I don't think you have an MacBook Air!
完成的
添加一条评论
添加你的答案
John 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 4
总计 116
