跳转到主内容
Model A1224 / Mid 2007 and Early 2008 / 2, 2.4, or 2.66 GHz Core 2 Duo processor
549 个问题 查看全部
Screen goes black after 1 sec
  1. I can hear charm sound and for 1 sec the screen is gray and after it goes black. I can see login window if I put some light on it. all lights are green, I bought used inverter on eBay but it didn’t change anything. need advise what can it be. Thanks
  2. also have 24” 2007 iMac with similar problem. this one goes on and everything is working, I’m able to login and after it goes to black screen same way that I can see it if I put some light on it. if I turned it off and turn it on without waiting it goes to black screen sooner or even right away. If I wait then it goes black after login.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You got a bad inverter. Return it and buy from a trusted seller.
I found this one:
https://www.fasttech.ca/imac-20/imac-int...
DSue to the age of this machine you are not going to find many listed.
If all else fails, I may have one in stock.
这个答案有帮助吗?
得分 1
2条评论:
How to know for sure that it’s a good one or bad one? Do you think 24” has the same problem? Thanks for your help!
完成的
Same symptoms, same answer.
完成的
添加一条评论
添加你的答案
olga 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 4
总计 53
