跳转到主内容
型号 A1136 / 30, 60, 或 80 GB 硬盘 / 黑色或白色塑料面板
797 个问题 查看全部
Why is my iPod emitting a high pitched noise from the click wheel?
Basically whenever my ipod is up and running, I can hear a high pitched whine/buzzing coming from the click wheel. Ipod works just fine, however i’m just wondering if I should be concerned at all? It gets a bit louder when charging. Haven't noticed any overheating issues when charging so far. Edit: I did take out the original hard drive and installed the iflash solo with a 3000mah battery. I want to say it's coil whine, but idk if that's possible with the iPod.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Is it the hard drive making noise. Those go out after a while. I just changed mine to a iflash with sd cards.
这个答案有帮助吗?
得分 0
2条评论:
Well that's the problem. I don't have a HDD installed anymore. I have the iflash solo with the 3000mah battery setup. So I'm just not sure if something happened to the logic board or if the click wheel is making the noises. I'm sorry, I should've mentioned the iflash mod
完成的
I have no idea why it is making noise. I can't think of anything that would make noise except the hard drive.
完成的
添加一条评论
添加你的答案
Michael Manzanares 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 293
