跳转到主内容
加入维修社区 - 创建账户
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
My iMac won't start? Black screen
Anyone having any tips why my iMac won't start? When I press power on the startup check is running and the CD ROM makes noise, when it continues the computer just shutting down and tries to boot one more time. This goes forever. The screen is black the whole process. Can it be hard drive failure? I've opened it up, but can't see any failure on mobo. Any tips appreciated :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
6条评论
Let's give this a try: Restart your system and this time press and hold the T key to enter into Target Disk Mode.
Reference: Mac startup key combinations Do you see either a FireWire or Thunderbolt Icon on your screen?
完成的
Thank you for reply. The screen doesn't turn on at all so I can't use the keyboard or mouse. The CD ROM makes noise, then it shuts down again.
完成的
Did you really give it a try as I outlined?
You may need a USB keyboard to get it to work.
完成的
I tried with the keyboard that comes with iMac. Connected via lightning cable to the USB port
完成的
I've uploaded a video on YouTube. https://youtu.be/ieMaSefDHwc
The sound might be a bit low
完成的
显示更多的1条评论
添加一条评论
1个答案
最有帮助的答案
The 2011 27” iMac has a well know issue with the GPU failing. For a while Apple even offered a repair program for it. For a short period it extended this program but was very quite about it:
https://www.techradar.com/news/apple-may...
To see if this is your issue, hook up an external monitor and see fir it works. If it does , then the GPU is not your issue. If it doesn’t then you need to replace the GPU.
I replace it with a better 2GB card as just replacing the original may result in the same issue.
NEW 661-5969 661-5968 Video Card AMD HD 6970M 2GB For iMac 27" Mid 2011 A1312
https://www.ebay.com/itm/NEW-661-5969-66...
这个答案有帮助吗?
得分 2
3条评论:
Thanks for the reply. I've uploaded a video to YouTube that maybe describes the problem better https://youtu.be/ieMaSefDHwc . Do you still think it can be the GPU? When pressing power on it starts for like 5 seconds then restart again :s
完成的
I'm getting no sound on your video.
完成的
The audio is a bit low, but it's there
完成的
添加一条评论
添加你的答案
Stian Ask 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 320
