跳转到主内容
Repair guides and support for your Philips TV.
227 个问题 查看全部
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What is the model number of the TV?
完成的
添加一条评论
4个答案
已选择的解决方案
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
这个答案有帮助吗?
得分 6
添加一条评论
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
这个答案有帮助吗?
得分 2
3条评论:
I have a Toshiba TV SUAZBe3DB and I have the same issue. Any tip please?
完成的
I also have a toshiba and have the same issue, please help!
完成的
I also have a Toshiba TV (only 2 months old) that's decided to do this, it's going through the window if I can't sort this, any help would be massively appreciated
完成的
添加一条评论
I found an answer, on my Mum's TV remote there is a language button, pressing it brings up the word English on the TV, pressing OK brings up a menu that defines the channels for the channel up and down buttons. Who knew that was there! It is very well hidden.
Once I found it fixing it was simple.
这个答案有帮助吗?
得分 2
3条评论:
I've been pulling my hair out for weeks and you've only gone and sorted it for me, I would never have found that, worked 1st time, thank you so much Mandy.
完成的
It's a terrible design to put that menu item there, glad you are fixed now.
完成的
Thanks, you have given me the answer too
完成的
添加一条评论
Channel changers generally have a favorites position. It may be in that mode now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David James 将永远感激不已
浏览统计数据:
过去 24 小时: 8
过去 7 天: 89
过去 30 天: 414
总计 8,567
