跳转到主内容
Repair guides and support for your Philips TV.
220 个问题 查看全部
Why is "Channel up" on my TV remote jumping to channel 700 when press
Every time I press “channel up" it jumps to channel 700 (radio) regardless of what channel I start on. If I continue pressing it after that, it scans up as normal, until it reaches the first TV channel, and then it goes back to channel 70/ again. I have a 10 month old daughter, so I suspect she's pressed something on the remote. Everything else works fine.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi,
What is the model number of the TV?
完成的
添加一条评论
3个答案
最有帮助的答案
Click ‘List’ (the button symbol is three horizontal lines, kind of like a cheeseburger symbol). Change the setting in the drop down from ‘Antenna Radio Channels’ to ‘All Satellite Channels’
这个答案有帮助吗?
得分 5
添加一条评论
Thanks this helped for my Sharp Aquos Smart android TV, I had the same. Whilst in a TV or radio channel press MTS > language displays e.g. English > press ok then hit < left or right > until you see “all channels” at the top of the panel.
这个答案有帮助吗?
得分 1
添加一条评论
Channel changers generally have a favorites position. It may be in that mode now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David James 将永远感激不已
浏览统计数据:
过去 24 小时: 13
过去 7 天: 120
过去 30 天: 462
总计 7,488
