跳转到主内容
加入维修社区 - 创建账户
型号 M8407 / 550 或 667 MHz G4 处理器
Question mark folder strange issue
I have a G4 titanium that has a strange issue. I have a working hard drive in it. When I put it into target disk mode, I can boot other systems off the hard drive. When I try to boot the machine itself it gives a question mark folder. I have system 9 and OS X tiger installed on it. When I press alt at startup it shows only the OS X install. Clicking on it just resets the boot selector. Same thing with 10.3 and a cd. What should I do? Thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Reaching back through the cobwebs to the very back room of my brain, I find a pile of papers half faded and out of sorts with no order. So as I piece the sheets back in some as-semblance of order…
I think I remember Tiger offered dual boot within its self. No true dual partition so you could run older OS-9 apps within it. Some people also did a proper dual boot setup as well, that’s when you setup the drive with two partitions completely isolating the OS and app spaces.
So the fact you see only the one startup disk is not unexpected.
As for your question mark always showing up.
This is caused when the PRAM battery has died! I hope you like the game of finding Waldo as we have a bit of a hunt to find it!
Follow this guide to get the optical drive out of your system PowerBook G4 Titanium Onyx DVD 驱动器更换 then pick up from Step 6 from this guide PowerBook G4 Titanium DVI PRAM 电池更换. Lift the battery board fully out so you can get to the battery.
PowerBook G4 Titanium Onyx DVD 驱动器图片
指南
难度:
中等
PowerBook G4 Titanium DVI PRAM 电池图片
指南
难度:
中等
这个答案有帮助吗?
得分 1
3条评论:
I would never have thought to replace the replace the battery, Apple computers don’t make much sense! Thank you I will open it once more and replace the battery see how it goes. Thank you
由完成的 分享
@idintfixit - Don't forget to score & accept the answer if you're set!
由完成的 分享
its the next day, got a new battery and it actually worked! crazy! thank you!
由完成的 分享
添加一条评论
添加你的答案
Mihai Paun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 18
总计 581
