跳转到主内容
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
101 个问题 查看全部
Why is my iPad screen not working after replacing screen and battery?
After I replaced my iPad 5’s screen, battery, and home button assembly, the screen won’t turn on until it is plugged in. Once the screen is on, it is covered in vertical and horizontal colored lines and there is a vertical black strip roughly an inch wide going down the middle of the screen. I’ve already taken the glass screen and the lcd screen off and checked all the connections multiple timed and all of them seem fine. All of the cables are also intact as far as I can tell. I don’t think it’s a problem with the lcd either because the colored lines are fairly uniform and there aren’t any black blotches like I’ve seen in a lot of damaged lcd pictures. Is there anything else I can do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It sounds like a bad connection. Get a magnifying glass and check all of the connections for damaged or bent pins. If they are fine try cleaning the connections with a qtip and alcohol and a soft brush. Make sure to disconnect the battery before you disconnect the screen.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lily R. 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 49
