跳转到主内容
加入维修社区 - 创建账户
WowWee CHiP Robot Dog, an automated AI pet which you can control and play with. Released in early 2016.
Wheels roll when picked up but wont move chip
Hello I just got my son a used chip robot his wheels roll but they will not move him I'm not sure if there is something I can do to fix that thank you
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
2条评论
got the same probleme on an ebay buy. looking forward guys to jeep posting how you solved the problem and what Heard You changed and where did you find them to buy new replacement ones. good luck!
完成的
can anyone give a guide to change the gears?
完成的
添加一条评论
2个答案
已选择的解决方案
Some of the plastic gears in the wheels will be damaged (if you try turning the wheels by hand you will probably feel them grind and stick, they should move freely). It’s a complex job because you need to remove most of the internals to get to the legs, but then then you can inspect the gears that are damaged and replace them. Use silicone grease on the new gears to keep things moving freely.
这个答案有帮助吗?
得分 2
8条评论:
Thank you so much
完成的
It’s an easy job a few screws finding the gear is another story It’s the gear on the motor shaft that’s bad was able to get some gears but they’re not quite as large still looking
完成的
Hi, we have the same problem, all 4 legs roll but very weak so when placed on the floor none of the legs move. Is it a central gear?
完成的
Same problem here, weak turning of wheels, won't turn on the floor. I've gotten it torn down to the gear boxes, now to see which one(s) may be damaged...
完成的
same issue bought one the lady claimed worked great his wheels spin when held but once on the ground he wont move. opened up found that the gear on the motor itself was broken all the teeth looked good but in one of the splines it was broken in to. This is what you will need to fix. Plastic Gears Model 082A, 8 Teeth, 0.5 Modulus, 5mm Outer diameter, 5mm Thickness, 2mm Hole Diameter. you can find these on amazon 50 for about $7. the replacement is quite easy.
完成的
显示更多的3条评论
添加一条评论
Tengo el mismo problema. Gira he intenta andar pero parece no tener fuerza. Si lo empujas anda un poco. Voy a desmontarlo siguiendo los pasos del manual de desmontaje para cambiar los engranes dañados.
这个答案有帮助吗?
得分 0
2条评论:
El manual desmontaje lo podéis encontrar aqui:
https://www.fictiv.com/blog/posts/wowwee...
完成的
Hola tengo el mismo problema el o los engranajes que deberia verificar los de cada pie o las dos cajas que están en el cuerpo. U na foto ayudaría. Gracias
完成的
添加一条评论
添加你的答案
Jennifer Rodriguez 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 22
过去 30 天: 68
总计 5,163
