跳转到主内容
A1708/EMC 3164—于2017年6月上市,这台入门级MacBook Pro保留了它的传统功能键(相对于OLED触控条)。
Reseating the LCD cable?
Hi,
I believe that I need to reseat the LCD cable on my MacBook Pro as the screen is black but the backlight still works. I cannot find a simple description of how to do this. Any advice would be appreciated?
Thanks in advance!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Unlike the older 2015 retina models which had the display cable route through the hinge with a connector on the logic board as seen here:
Apple made a radical change! Using a set of ribbon cables which went between the upper case and the lid. Here’s the layout of these cables:
Photo credit: @just1ed www.macplus.sg
The logic board at the bottom of the image sits inside your upper case (T-CON board) The T-CON function was held inside the display lid with the LCD panel in the older 2015 systems, now it sits here with the massive group of lines running between. None of these cables are serviceable so nothing to reseat.
So where does that leave us ??
Sadly, the full display assembly needs to be replaced as the T-CON board has failed. Remember as I described things this board is part of the display assembly and not serviceable on its own, which is why you need a new display.
Here’s the needed part:
And here’s the guide to replace it 2016后期带功能键的13寸MacBook Pro显示屏组件更换
这个答案有帮助吗?
得分 0
1条评论:
So, is there absolutely nothing I can do apart from getting it serviced?
完成的
添加一条评论
添加你的答案
Lilly Beans 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 9
过去 30 天: 28
总计 1,839
