跳转到主内容
加入维修社区 - 创建账户
Toyota's fifth generation Pickup
AC clutch won't engage
5/1989 Toyota 4X4 pickup w/22RE. AC clutch won’t engage. If I run a jumper to the clutch power wire, it works. Multiple wiring diagrams vary considerably and do not show location of AC relay and related electrical components. 10 amp fuse behind glove box is good.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
check you ac fluid level if its to low the clutch wont engage
完成的
添加一条评论
1个答案
The 10 amp fuse doesn't go to the ac clutch. The first thing you should do is see if it has freon in it. It has pressure switches that would engage the clutch unless there is enough pressure in the system. It could also be a ac relay but my guess is it's low on freon and it's r12 originally and will have to convert to R134A. First have someone put a ac gauge on it and check the pressures.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Geoff McLeod 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 1,904
