跳转到主内容
Optical Drive Installation problem?
I dropped my lovely macbook pro and the optical drive quit working. I ordered a new drive from powerbookmedic.com and put it in but its not working. Is there any setting I need to change or software I need to change?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
2条评论
Just how is it not working? Did you format it and install a system?
完成的
All I did was plug it in, I need help with what I need to do to format and install it. Also, I mistyped that, its the OPTICAL drive, not the HARD drive.
完成的
添加一条评论
1个答案
已选择的解决方案
Hi Jordan,
If it is the optical drive that you are trying to replace, is shouldn't need a software update in theory. Perhaps there is something else wrong, or there is a problem with the new optical drive.
To test wither or not it is the new optical drive that is broken you probably should contact your supplier and see if they can exchange it for you and try again.
Or you can get SATA Wondercable plug in the optical drive and see if it runs.
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
Jordan Filbrun 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 1,352
