跳转到主内容
Can I replace battery of MacBook 2018 by myself?
Hello. The battery of my MacBook Pro 13” 2018 are swollen, but the authorized merchant tells me that they don’t replace only the batteries and instead of 129$ of battery replacement I have to pay 425$ for replacement of all bottom part. So I don’t want to pay so much and I want to to this my myself.
I tried to find a battery, and I found it, (not original) but one of sellers told me that they don’t sell batteries for a1989 because of they aren’t compatible because of chip T2. Is it true? Can I buy the battery and replace it? Will I have some problems with T2 chip?
also, can I use my MacBook without battery while I’m waiting for the shipment of new battery?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
This gets tricky! While the battery is available it can’t be shipped by air. So you are limited on where you can get it. As an example in the EU you could get this one 18/19 13” MacBook Pro 13" Battery (4TB ports) Apple P/N 820-01118 and here’s the guide 2018年款带 Touch Bar 的13寸 MacBook Pro 电池更换
If you have a friend traveling to the UK they could pick it up for you as they can hand carry it on the plane.
While you can replace the battery alone, Apple won’t! They only replace the full uppercase which is what the person was trying to tell you as they don’t have a in-house service center. and Apple also requires them to use their parts so that limits them on what they can do. An independent repair outfit is not bound by Apples rules.
这个答案有帮助吗?
得分 0
2条评论:
Thank u for your response, also thank u that u gave me a link to buy, but I just bought the battery that will come to me from USA. (I’m in Mexico)
Due the pandemic the waiting could waists some long and I need my computer, so I want to know can I use my MacBook without the battery? I saw that one person here used his MacBook 2018 without the battery, but that was
完成的
Ouch! Mexico will be difficult! Sorry I don't know of any suppliers there. I think your only choice is going to an Apple Store or an Apple authorized service center to get it fixed for you.
Sadly your MacBook Pro requires the battery to work. The design of the older models with MagSafe power could be used. The newer systems like yours requires it as the system will go into Safe mode dropping the CPU's clocking way down to the point of being useless.
完成的
添加一条评论
添加你的答案
Estebán 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 14
总计 270
