跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
Burnt out coil on motherboard and the device isn’t powering up
hi there guys just recently started researching about microsoldering. I have this iPhone 5s which after inspecting seems to have 2 burnt out coils just near the charging chip. I will uploads pics to show.
the iPhone isn’t powering up. Will getting the coils fixed repair the phone. Or does any one have any help as to where I should start. Thanks
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
I would definitely start there. When you remove the coils it would be easier to check for shorts. You should be able buy a broken phone for donor parts. If you are going to do this yourself I would recommend practicing on some junk boards or have a professional do the work.
这个答案有帮助吗?
得分 0
6条评论:
This is a junk board I have lying around. Do you think the coils could be the reason for not powering on?
Also how would you remove the coils. Do you have a YouTube video or instructions this is going to me first attempt at something like this. Thanks
完成的
Watch videos from jessa at iPad rehab, jason at sts telecom, and Louis rossmann on YouTube. You will need a hot air machine and a soldering iron. You can buy a cheap one on Amazon but the quality is soso. If you want to learn how to do this and are interested in maybe doing it for a living or side income I would recommend getting some decent equipment. Like a amscope 7x45 microscope with a camera mount. Hakko fx951 soldering station and fx2032 micro pencil and some hot tweezers. You can purchase all of the equipment on Amazon.
完成的
Okay great I’ll take a look now
完成的
According to schematics it is l2_rf and l3_rf
Which seem to be the burnt out ones anyone know where to purchase these 2 from?
完成的
I am not sure. Are you in the us?
完成的
显示更多的1条评论
添加一条评论
添加你的答案
Rakesh 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 5
过去 30 天: 7
总计 148
