跳转到主内容
Explore comprehensive repair and disassembly guides for a wide range of food-cooling appliances. This is your go-to solution for troubleshooting and fixing refrigerators, fridge-freezers, and other cooling units. Whether you're dealing with common issues or looking for step-by-step instructions on specific models, our detailed guides cover everything you need to keep your appliances running efficiently. Perfect for both DIY enthusiasts and professional repair technicians.
1699 个问题 查看全部
Can I Repair condenser?
My fridge freezer is leaking freon gas from the condenser pipe. I'm thinking to wrap special leak tape or use paste that is designed to stop leaks. Is this safe to do? And am I able to re-gas the unit myself and equipment would I need to do it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi
What is the make and model number of the refrigerator?
I don’t think that a sealing tape or paste will be good enough as although the refrigerant becomes a liquid from a gas as it passes through the condenser it is still under pressure as the sealed system in a refrigerator is a pressurised system.
It may also depend on what type of refrigerant the refrigerator was designed to use. Depending on your location you may have to use a licenced refrigerator repairer to fix any problems with the sealed system so as to comply with the environmental regulations regarding the handling of refrigerant gases and to be able to buy the refrigerant. You cannot buy it if you’re not licenced.
To repair the system you would need the equipment to do it properly. You would need to get into the sealed system and pump out any remaining refrigerant, repair the leak in the condenser using soldering techniques etc then when it is fixed, create a vacuum in the sealed system to remove any air from the system and pump in the new refrigerant. After this the high and low pressures in the system would need to be checked to ensure that there are no leaks and that there was enough and not too little or too much refrigerant so that the refrigerator would cool properly and efficiently.
这个答案有帮助吗?
得分 0
2条评论:
Thank you for your reply. The model number is: KAD62S20/06. It's 9years old
April the freezer was not freezing so I called BOSCH. an engineer came checked the unit said the compressor is faulty and needs replacing. another BOSCH engineer arrived but he checked the freor and said the gas is low, he vacuumed the system and re-gassed the unit saying the pressure is holding.the engineer said it could have been a blockage. So after a few months the unit was working perfectly. But I turned off the unit as I wanted to clean the inside. After turning it back on the next day I noticed the freezer and fridge wasn't cool. called BOSCH, engineer arrived and without any checks said there was an internal leak and nothing could be done.anotherengineer re-gassed the unit and said he sprayed liquid that detects leaks but no sign of leak. At night I heard a strange cherping sound from behind the unit. I saw bubbles forming over the condenser pipe. Bosch refused to help
完成的
@Ikram Haq
If it is a blockage or leak in the condenser then as @barriphone suggests try replacing the condenser. Contact a reputable, professional fridge repair service, explain the problem and ask if they can fix it and how much it would cost.
Here's some examples of how much the part may cost just to give you an idea of the "parts component cost" of the repair
Example 1- UK
Example 2 - USA
完成的
添加一条评论
It's a possibility that the condenser can be soldered but you would need a professional to look at that. There is no sealant tape that will stop the leak. The low pressure is around 40psi and the high side is at least 230psi. Check with the repair man and see if he can replace the condenser.
这个答案有帮助吗?
得分 0
2条评论:
I have contacted many engineers, some say not to bother repairing and others haven't got back to me. It seems to me that engineers think it to be a bug job or can't be bothered to help me get the unit repaired.
Is replacing the condenser a big job? I don't understand why no one wants to do the job. I'm not asking for the job to be done for free
完成的
I would try a commercial repair place
完成的
添加一条评论
添加你的答案
Ikram Haq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 19
总计 1,764
