跳转到主内容
苹果官方于2015年9月25日正式发售iPhone6S A1688/A1633机型。 此机型的修理方式与先前几代差不多, 需要螺丝起子及撬棍工具。 同时也适用GSM or CDMA/16, 64 or 128 GB/ 银色, 金色, 深空灰色, 玫瑰金色等机型。
LCD lines on display/blacks out
Hello. I have a personal Iphone 6s that I decided to buy a new housing which has back glass but unfortunately alot of things didnt sit flush (camera, aux connecter had to be cut etc) so I decided to return the product and move all the stuff back to its original housing. I moved all the stickers etc and the logic board doesn’t seem to have had any damage. But when I connected the display and turned the phone on (after connecting the battery last ofc, and disconnecting the battery first out of anything) the display has alot of lines or sometimes wont even turn on. But the black light still turns on. I played with it a little and when i have the screen in an odd position the display works perfectly fine. The connecters on the logic board seem fine, aswell as the LCD connecters seem fine. My guess is the FCP flex cable is broken due to too much bending. Any help would be appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
I provided photos. The LCD connecter is fine on the logic board and so is the pins on the LCD screen. As for the camera and home buttons on the LCD screen AND logic board, they are subject to opinion. I dont mind no front camera or homebutton as I wont use the front camera at all and the home button can be fixed with the on-screen homebutton.
完成的
添加一条评论
1个答案
最有帮助的答案
It's a possibility about the cable but another possibility is a bad connection. Unhook the screen and make sure the pins are in good condition and clean the connectors with a qtip and alcohol and a soft brush.
Update (07/14/2020)
It sounds like the screen was damaged. I would try another screen.
这个答案有帮助吗?
得分 1
1条评论:
The front camera pins are slightly damaged on the logic board. Maybe 1 or 2 pins are exposed. Ive already cleaned them and when I put the screen in that odd position the front camera still works. The LCD pins are perfectly fine
完成的
添加一条评论
添加你的答案
Narciso Sanchez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 57
