跳转到主内容
Model A1286. Released February 2011 / 2.0, 2.2, or 2.3 GHz Quad-core Intel Core i7 Processor
586 个问题 查看全部
Charging adapter extremely hot while charge
Hi there.
Is there normal when charging tip is so hot it is unable to touch it while it is chargin.
I got 15inch MBP 2011 - I know it suppose to have 85W charger - and I use 60W charger - but I remember with my other MBP 15 2011 it was ok - with this one - it is extreme hot
MacBook is charging as normal
Or is it possibe it is happening as charging port inside macbook has peeled that “grey plastic sticker” and now has bare metal.
Other thing is - when MacBook is in sleep mode - charging tip is ok - just warm
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Yes because that model needs the 85W charger. When the 60W charger is being used it is using the full power capacity of the charger which is why it is hot to the touch.
这个答案有帮助吗?
得分 2
2条评论:
no it is not true.
1. I am using 60W charger - not 65W
2. Charging tip must be damaged as I purchased new charger - it is almost cold to touch while charging.
3. Fun fact was that - that "damaged" charger is workign perfectly fine.
Crazy
完成的
If the other 2011 was an nvidia gpu model and this one is an AMD model one must be using more power than the other
完成的
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 21
总计 1,588
