跳转到主内容
installing HDD from another MacBook
Trying to install a HDD from one Macbook Air to another without losing and data.
All steps online seem to just guide you when dealing with a blinking folder.
Just want to get thru this without losing the original data on the HDD.
Which options should I choose?
Restore from Time Machine Backup?
Reinstall OS X?
Get Help Online?
Disk Utility?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
If they are the same computers, is a plug and play task. If they are not you have to consider SATA and PCI-Express SSD and EFI version, new version of EFI chip only read new apple file system.
这个答案有帮助吗?
得分 1
4条评论:
The transfer is from an A1466 to an A1465 model. The A1466 model was damaged but the SSD seemed fine. I want to install it into the A1465 and hope to keep all information on it. Currently after installing it I get the blinking folder.
Thank you for your help.
完成的
What year is the a1465 model. It needs to be 2013 or newer to definitely fit in the MacBook.
完成的
The unit fits for sure.
完成的
Tony - Review this guide compare your two systems SSD's Apple Proprietary SSDs - Ultimate Guide to Specs & Upgrades make sure they are compatible.
The next issue is the version of MacOS the drive has. If you hadn't upgraded your OS to High Sierra or newer then your system is still using HFS+ file system, High Sierra and newer uses APFS which also requires the systems firmware to be upgraded as your older firmware (OS) has no idea how to read there newer file system.
完成的
添加一条评论
Two ways to go:
  1. Boot from and external USB source. Hard drive with a system on it and a USB to SATA adapter and recover your data from the internal drive
  2. Install your new drive and do an internet recovery to install the new system. Put your old drive in an OWC Envoy Pro enclosure and then access your data https://eshop.macsales.com/item/OWC/MAU3...
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Tony 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 132
