跳转到主内容
加入维修社区 - 创建账户
2016年9月16日发售。型号有A1661,A1784和A1785,支持GSM 和 CDMA 格式,存储容量有32GB、128GB以及256GB,颜色有玫瑰金、金色、银色、黑色、新的亮黑和红色。
Why back camera and flashlight does not work?
My iPhone 7 fell before, and it’s LCD broke right after.
The digitizer was totally fine, since I’ve tested it right after.
But after replacing the screen back camera and flashlight does not work ( I know that these depend on each other, so well-known problem).
But after several troubleshoot it does not work at all, let me share what I’ve tried so far.
  1. Reset settings, nothing changed.
  2. Erased all data, nothing changed.
  3. Voiceover turned off,nothing changed
  4. Used iTunes to erase and install latest firmware, nothing changed.
  5. Did not find obvious damage on motherboard. Gave a good IPA cleaning to the connectors either, nothing changed.
  6. The connectors are not damaged, they seem to be perfectly fine.
  7. Switching between front and back cam, nothing changed.
  8. Individually turning on flashlight, nothing happens.
  9. LED notifications does not work either via flashlight
  10. Battery health is 95%, so I think that is not the reason.
Any other suggestions, maybe other than micro-soldering?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
It needs the flashlight ic replaced. It's a common problem.
这个答案有帮助吗?
得分 0
2条评论:
Do you think I could buy a spare flashlight IC and replace it at home?
Or how much it usually cost in a service?
完成的
You could do it if you have the equipment and skills. You will need a soldering iron and a hot air station. Along with other miscellaneous supplies and equipment.
完成的
添加一条评论
添加你的答案
balazs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 67
