跳转到主内容
2015年3月更新的 13 英寸 MacBook Pro 配备 Retina 显示屏,型号为A1502,采用第五代英特尔酷睿 i5 和 i7 处理器,并配备 Force Touch触控板。
1185 个问题 查看全部
What do I need to do exactly to replace keyboard?
No specific guide, just looking through other QAs and videos. But can someone clarify something…
I’m following the 替换MacBook Pro 13‘’Retina显示器2015年早期版本的主板 Logic board replacement guide… but they removed the heatsink.
I do NOT need to do this if I just want to replace the keyboard right?
Is there anything else in the guide I should not need to do for keyboard replace? I’m trying to make this as simple as possible.
Once I removed the logic board, other board, fan… It’s a matter of peeling the backlight off gently, and then using some force to remove the old keyboard…
And from what I understand, the old keyboard rivets will come off mostly revealing screw holes to screw down the new keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Since late 2012 Keyboards on Apple Laptops are not easy to remove anymore, that is the reason why you don’t find a good guide because to do a clean and good job you have to replace the entire middle frame/housing for a new one with keyboard included.
Now if you have time and you want to save money you can remove the keyboard and install a new one. Youtube Tutorial in the minute 30 and up you can see how the keyboard is attached to the middle frame, if you want a solid job you have to be creative.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
h7nry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 9
总计 417
