跳转到主内容
The third-generation Ram was unveiled on February 7, 2001 at the 2001 Chicago Auto Show. This was a major update including an all new frame, suspension, powertrains, interiors, and sheet metal.
81 个问题 查看全部
How do I replace the AC condenser cooling fan relay?
How to replace AC condenser cooling fan relay?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
Find the relay and lift the clips on each side and pull it out.
这个答案有帮助吗?
得分 0
2条评论:
Where is the relay???
完成的
It probably in the relay box under the hood. Or it could be the the firewall or the radiator cross bar. It could also be on the fan frame. Check a repair manual.
完成的
添加一条评论
添加你的答案
Francis Jansen 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 11
总计 90
