Screen keep pressing on a middle vertical line after screen replace
Screen keep pressing on a middle vertical line after screen replacement. Previusly the screen wasn’t responding in the same area, then i tried to clean the pin with alcool and now it keep pressing.
Aggiorna (07/07/2020)
Update: now it simply do not work on the same vertical area.
sounds like you have a potential defect, but more likely there was an installation error that may be corrected by retracing your steps and ensuring good connection and nothing is bent/ broken. here are some links to help with this:
iPhone 6s 显示屏总成更换
iPhone 6s 屏幕更换
take youre time and ensure nothing was missed. make sure to look closely ( with magnifier/scope if possible) for any broken /bent pins. if nothing is damaged and all the steps were followed correctly, then i would contact the vendor and discuss the issue and about a possible replacement part.
由 jostewcrew 完成的
