跳转到主内容
Will it boot with the trackpad disconnected?
The trackpad went wonky. It won’t click and it moves the cursor with a lot of “effort” if you will. I’ve also found that if I plug in a mouse after it’s booted, that mouse won’t “click” either. But if I plug the mouse in before booting, the machine appears to ignore the trackpad and the mouse works fine. That is, until I touch the trackpad and wake it up. Then I’m stuck again. So, rather than replace the battery & trackpad in this aging machine, I’d like to just disconnect the trackpad altogether and use an external mouse. But will it run correctly this way?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
You may have an easy fix here! So let’s not throw the baby out with the bathwater!
To be clear you need the trackpad connected as it has a thermal sensor SMC requires. If you disconnect it you’ll face a very slow system! As SMC will place the system is Safe Mode cranking up the fans and lowering the CPU’s clocking so it won’t over heat.
OK lets fix your system! You’ll need to fully remove the trackpad as its gotten gummed up! Follow this guide MacBook Pro 13" Retina Display Early 2013 Trackpad Replacement follow it to Step 9 removing the interposer board, then jump to Step 21 & 22 removing the SSD.
So far we’ve jumped over a lot of steps which are not really needed. I’ve found an easier way!
Now we do need to jump to Step 35 & 36 as we need to disconnect the trackpad cable so we can slide it out but if we do that without removing the battery we’ll have a hard time getting it back! So we need to attach a pull back to the cable!
Basically, taking a strip of electricians tape attached to the tab and the cable that we can reach and then taking a second strip to cover the adhesive surface about eight inches. The battery is not glued to the cable but we will need to carefully raise it a bit without damaging it at the logic board end. We do have a strip of adhesive holding the cable down just inside the SSD hollow (you can see it in Step 39 first image). Use a thin spatula to carefully lift the cable off. Now carefully pull the cable through a bit about an inch.
Now Jump to Step 40 & 41 removing the screws and plates Then in Step 42 we’ll push the cable slack through the slot so we can then get the trackpad dislodged. Once its loose you can then gain access to the back side to disconnect the ribbon cable from the trackpad. I do recommend to use a sharpie to mark the cable so you know which side the cable goes in. Carefully lift the clamp bar to release the pressure on the cable.
OK, we've got it out now what? Surprisingly I find using some cleaner along the upper case edge as well as the trackpad is all thats needed to clean things. You want a just damp micro-cloth (to much will damage the trackpad). I would just use fantastic spray a short spray onto the cloth is all I do.
Once clean reverse the order! After you put the trackpad screws back in give it a test. Do you hear it click when you press? You should see the trackpad depress ever so slightly.
这个答案有帮助吗?
得分 2
4条评论:
I'm finally getting back to trying this. It sounds promising. But one thing I want to clarify. When I said it doesn't "click" I meant that it doesn't work in the OS. Physically it does "click". I can press it down and it sounds and feels like it should. But it doesn't cause the mouse click function in MacOS. For this reason, I'm not certain that this is a cleaning issue. But I can give it a try.
完成的
Thats sounds like the trackpad its self needs replacing then MacBook Pro 13" Retina (Late 2012-Early 2013) Trackpad If you look at the logic board on the backside, you'll see a silver blister button switch in the middle which in your case has failed.
完成的
I finally got around to finishing this repair. I ordered a used trackpad on eBay and decided to just swap it entirely. Everything went well. I used kapton tape instead of electrical tape. It seemed like it would be a little thinner and less "grabbie" sliding through. It worked pretty well although a 3rd (or even 4th) hand would have been nice. It took just a little bit of lifting on the battery to make the ribbon slide freely.
Thanks for the help and encouragement!
完成的
@gawarren - Happy to hear you're up and running again! I knew you could do it. Enjoy!
Don't forget to score the answer and accept it
完成的
添加一条评论
添加你的答案
Gawandy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 41
总计 788
