跳转到主内容
加入维修社区 - 创建账户
2017年9月22日发售。型号有A1864,和A1897,可选GSM 和 CDMA 网络,存储有64GB和256GB,颜色有金色、银色和深空灰色。
water damage indicator checking
hello for all wish you all nice day please can you tell how I can know if my iphone 8 plus has water damage i see some topics saying from the sim try slot and other said from motherboard can you please tell me how i can know using both methods ???
note : I attached an 8 plus motherboard tell me please where is the indicator
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
4条评论
Can you take a close up picture of the top left side of the board were the antennas connect please
完成的
And a picture of the other side of the board
完成的
@barriphone finally some one reply I was waiting since 10 hours this picture is just for information I want to know how I can determine if it has water damage or not please explain the method for me sir
完成的
You need to take the board out and physical inspect it for corrosion. Check and see if it's been wet. Was water inside the phone. Pull off the black coveralls and check under them. The water Mark's don't really mean anything. If you have high humidity it can cause them to turn red. The only way to tell in to physical inspect it.
完成的
添加一条评论
1个答案
最有帮助的答案
the only way to really determine water damage is to open the phone and look at the LCI.
if you take a look at your picture of the motherboard you posted, see the square at the upper left. look at the thin part of the board where this connects. there is a white oval just above a flex connector. that's the LCI. if it contacts liquid, it will turn red.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
tamer 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 139
