跳转到主内容
加入维修社区 - 创建账户
A small white or black laptop with the word Acer written in silver on the outside cover. The top has a woven fabric texture to reduce glare.
Is there a CMOS battery?
Hello !
I have an issue with my BIOS where i can’t change a thing in it and after several tries on installing different Linux distributions, it keeps failing to boot after the asked reboot at the end of the installation.
I can’t find the CMOS battery on my motherboard to hard reset the computer to factory mode, and I’m a bit ashamed lol !
If anyone can help me, i’ll take it ! Thanks in advance !
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论:
Hello friend, did you find the solution? I have the same problem.
完成的
添加一条评论
2个答案
When the ACER logo appears, press and hold ‘‘Alt+F10’’ until screen changes. Hopefully you won’t need to dig for the battery.
这个答案有帮助吗?
得分 0
3条评论:
It doesn’t work at all ! This combination of keys don’t make a thing and I can’t edit anything other than the date / hours + the user password on the Bios, the others are grey
完成的
Then this seems to be an 1-way. Try to find a trustwotrhy disassembly guide for your acer. Blueprints are hard to find normally, so youtube might be the best choice.
完成的
That's why I posted here, I didn't find any blueprints or videos with my computer in two days lol !
完成的
添加一条评论
These Acer "Cloudbooks" use a capacitor backed CMOS RAM, with a reference BIOS setting stored in NVRAM. If the machine has problems with saving BIOS settings, it is due to a bad primary battery, as it is held with a supercapacitor on these. I do not see a CMOS battery on the motherboard on this laptop.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Odasio 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 29
总计 883
