Running issues after repair
I just replaced fuel pump spark plugs and wires and distributer cap now my car dont wanna stay running or once warmed up idles way to high? What could be my problem
Did you set the initial timing when you changed the distributor? It will not run correctly because it's trying ser the ignition timing from the factory base but if you didn't set it correctly it will try to find it.
这个答案有帮助吗?
Only changed the cap not the whole distributer or rotor.
What brand of plugs did you use?
And did you check the fuel pressure?
And what engine is it?
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 43
