跳转到主内容
Repair and disassembly guides for GE Microwave ovens.
349 个问题 查看全部
Microwave Oven turns on but the turn table does not turn
My GE Café 1.7 Cu. Ft. Microwave Oven turns on but the turn table does not turn and the Microwave does not heat up. What is the problem?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
Hi,
What is the model number of the microwave oven?
It sounds like a problem with the door interlock switches.
They are a safety measure designed to turn off the microwave if the door is opened during operation so that no microwave radiation is emitted.
There are usually 2 or 3 switches involved with the door interlocks. They could be broken, burnt out or loose. The oven would need to be opened and the switches checked.
Microwave ovens are dangerous to work on if you don’t know what you’re doing. If in any doubt contact a reputable, professional appliance repair service and ask for a quote
The HV capacitor can cause serious injury if it is not discharged correctly before any repair work is carried out. It can store >6000V DC for months even if the oven has been disconnected from the power for this length of time.
这个答案有帮助吗?
得分 0
添加一条评论
When everything else works except for the turntable, the usual cause is a faulty turntable motor.
Replacing the motor is not that hard if you are comfortable opening ou the oven (and be sure to follow the advice about the capacitor). So far I have replaced motors on two different microwaves.
My source for motors has been Ebay.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Harold Reed 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 8
总计 133
