跳转到主内容
Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1203 个问题 查看全部
High pitched electronic squeal
Over the past few weeks, I’ve noticed that my MacBook Core 2 Duo has developed a high-pitched squealing noise. It almost sounds like a high pitched record scratch with a variable frequency. It sounds like it’s coming from the back right side of the machine, near the power button and right side speaker. It seems if I tap the case hard enough in this area, it will temporarily stop, but it comes back fairly soon. It will also go for quite long periods without making the noise.
Volume controls and mute don’t affect the noise at all, and it will happen whether or not headphones are plugged in. Music and other audio plays out of both speaker and headphones with no issues. Performance and functionality of the machine don’t seem to be affected.
This is a pretty old machine that I’ve taken apart and put back together a TON of times for various reasons (fan, display inverter, LCD, bezel, keyboard/trackpad cable, hard drive, etc), so I wouldn’t be surprised if some other component has started to go bad.
My first impulse was going to be disconnecting the speakers to see if the sound would go away, but I thought I’d get input from the folks here first. Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
最有帮助的答案
If not what Dylan said, it could be a loose internal fan, hitting the sides. Or even dust blocking it.
这个答案有帮助吗?
得分 1
1条评论:
Yea that could be true, if it isnt coil whine. I dont have much experience fixing coil whine, but i assume a psu swap would fix
完成的
添加一条评论
Does the sound change if you insert a disc into the optical drive? That is a noisy component which spins and is located near the area you are describing. If so you may have a faulty optical drive.
这个答案有帮助吗?
得分 1
添加一条评论
It could be coil wine, look up a video to hear what coil whine sounds like.
这个答案有帮助吗?
得分 0
1条评论:
I listened to a few of the videos on YouTube, and it does sort of sound like that. Here’s a recording I made:
https://photos.app.goo.gl/J1sxnQkVhVc65s...
As I move around it definitely seems to be coming from the right side near the power switch and right speaker, and less from the center near the fan.
完成的
添加一条评论
添加你的答案
Peter Wood 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 9
过去 30 天: 9
总计 133
